Kiev 88 qui fuit
Zota
Re: Kiev 88 qui fuit
Message par Zota »
suaudeau benoit a écrit :Si tu met la pellicule juste sur la marque de départ au chargement, les dos Kiev anciens modèles permettent de faire 13 vues........
Eh oui, c'est logique :oops:
merci.
suaudeau benoit
Message par suaudeau benoit »
ça n'a rien de logique, c'est le petit plus des Kiev, inconnu ailleurs sur terre. En théorie, 6x6 sur pellicule 120, c'est 12 vues.
Zota
Message par Zota »
J'ai acheté un dos NT neuf. Évidemment il fuit, ça dévient une blague...
Voici la réponse du vendeur ebay :
I've contacted my service center (so some delay with response) - they said that filmback was adjusted using etalone camera of Kiev Arsenal. The use the same etalon for both filmbacks and camera bodies - so cameras and filmbacks adjusted using it don't have light-leaks problems.
But for older cameras, it may happen that camera is slightly let's say dis-adjusted because of the longer use - it's still works correctly and without any problems with native filmbacks, but may have issues using new filmbacks, or filmbacks from other camera... - so they advice alsways re-adjust camera in such case, to have it always fully compatible with all filmbacks (I know that photographers do this each 2..3 years, like with a car which must pass a regular inspection every 15,000km :-).
As for you - advices were --> (a / the best way) to check the camera's back-wall adjusting; (b / in case 'a' isn't possible) to adjust the filmback, in order to fit the camera / not recommended because it'll be working fine the only with your certain camera; (c / so so) to apply light-leaks kit to the filmback - I know that for ex. on the Kiev Report forum people offer such self-made kits; (d = a) to send both camera's body and filmbacks to Kiev, to be adjusted - for example ARAX offers such service.
Regards,
Zhanna
Le vendeur est grizzly33bear
Pour ceux qui ne lisent pas l'anglais en gros il dis que le dos est testé et que s'il ne marche pas c'est que ma vieille camera est adapté au vieux dos qu'elle utilise depuis des année mais qu'elle ne doit plus tout à fait correspondre à la perfection d'un dos tout neuf. Il faudrait donc que j'envoie ma camera pour une révision.
Un vrai salopard ou je me trompe ?
Gabou
Message par Gabou »
Je m'y connais pas mais je trouve sa réponse logique, et honnête. :|
Je crois qu'il est vrai qu'un dos pourra aller parfaitement sur une machine et pas sur une autre.
Et puis grizzly33bear n'est pas connu pour être un arnaqueur en plus.
suaudeau benoit
C'est quel type de fuite sur ton dos. (je connais la boite et il est possible de discuter, mais avec fermeté courtoise).
ALambix
Message par ALambix »
suaudeau benoit a écrit :C'est quel type de fuite sur ton dos. (je connais la boite et il est possible de discuter, mais avec fermeté courtoise).
exact, il faut d'abord déterminer qu'est ce qui fuit : la fente du volet, la jonction dos-appareil ou la fermeture du dos ?
Zota
Message par Zota »
Bien sur jusqu'à maintenant je suis resté très courtois.
Comment déterminer d'où vient la fuite ?
suaudeau benoit
Montre nous une image de ton néga avec les marge et un espace inter-image.
metallicavid
Message par metallicavid »
pour ma part, j'ai un dos qui n'a pas de fuite, mais je garde du chatertonne sous la main par sécurité, et ca prend pas plus de temps ^^
j'ai l'impression que le NT fait la meme chose que sur le mien
Zota
Message par Zota »
J'ai ouvert le dos en enlevant la dizaine de petites vis et là j'ai découvert qu'il manquait pratiquement tout la mousse. Alors je l'ai mise et voilà tout va bien maintenant. Plus de fuites.
Je facture l'intervention au vendeur ? :twisted:
suaudeau benoit
Sur un dos neuf?
benoit c
Message par benoit c »
ben, au moins tu lui fais remarquer, minimum. Te faire un speech prétendant que le dos a été contrôlé et t'expliquer que c'est ton appareil sur lequel il ne s'ajuste pas, ça fait moyen sérieux pour un dos qui s'avère être sans mousses!!! :?
metallicavid
franchement abusé !!!
ca en fait des kiev opérationnel désormais ^^
sur 4 j'ai un dos nikel et un autre assez bien, c'est déjà cela
est ce que demander à un forgeron de redresser la plaque est utile?
allez Zota, bon plaisir avec, j'ai recu mon 45 et 65 mm, un regal, le 80 est au placard
Image, sur Flickr
65mm
Image, sur Flickr
45mm MIR 26
FOMA @1600 1/2sec de pose
aucune fuite^^
suaudeau benoit
Moi je l'ai fait moi même avec une petite massette maison en bois dur. Comme le métal est franchement tendre c'est facile, des petits coups suffisent (aux endroits stratégiques évidement).
metallicavid
suaudeau benoit a écrit :Moi je l'ai fait moi même avec une petite massette maison en bois dur. Comme le métal est franchement tendre c'est facile, des petits coups suffisent (aux endroits stratégiques évidement).
j'ai un peu peur de faire pire ...
Zota
Message par Zota »
Le dos était bien neuf. c'était le N° 390262425003 sur la baie.
J'ai bien sur fait remarquer tout ça au vendeur. Je suis curieux de sa réponse.
A la masse... j'ai cru que c'était une blague, je comprends que tu ai peur :wink:
Amuse toi bien avec tes nouveaux cailloux !
Faut peut-être pas confondre MASSE et "une petite massette maison en bois dur" qui est en fait un petit maillet. http://www.ikonet.com/fr/ledictionnaire ... aillet.php ...
...n'empêche que si pas délicat, s'abstenir !!! :wink:
Modifié en dernier par P@dh le lundi 14 février 2011 4:45, modifié 1 fois.
suaudeau benoit
Moi je ne connais rien à tous ce que je fait, j'ai juste peur de rien, et j'apprends (un peu). :lol: Alors masse, massette, marteau pilon, c'est grosso modo le même instrument.
j'espère que vous cacherez ce petit secret à mes patients.......
ALambix
Les derniers posts sont tout simplement intolérables et je vais de ce pas demander l'intervention d'un modérateur pour biner ce fil et virer les auteurs !!!!!
Vous ne me ferez pas croire que les dernières photos sont issues d'optiques ukrainiennes montées sur un Kiev 88 !!!! Si un kiev 88 pouvait fonctionner de manière satisfaisante, ça se saurait !!!!!! Ici même des pointures de la micromécanique nanotechnologique nous ont dit le contraire !!!!
Ce fil est un ramassis de mensonge, un écran de fumée monté par des nostalgiques de l'ère soviétique dans le but de discréditer l'Ouest !!!!!
Ah mais !!!!!!
Pourquoi j'ai revendu mon Salyut-S moi....ah oui, pour rendre fiable un flexaret, qui dort maintenant et que j'ai remplacé par un yashica....
:lol: :lol: :wink: Super les gars !!!!
Je rassure les non initiés, c'est juste un petit délire, je connais la qualité des salyut/kiev.
metallicavid
le jour où tu retourne au kiev, ca va se voir ^^
d'alleurs, tu as créé un bon froid, plus rien après!!
alors zota, tu retrouve le plaisir de cette bête?
