ARAX-CM/MLU starter kit ? Kiev88CM révisé/remis à neuf et am
Leodium
Message par Leodium »
Bonjour, nouveau chez vous... Je me présente dès ce post fini...
L'avantage de ces appareils serait qu'ils sont des Kiev88 révisés/remis comme neufs et améliorés.
Quelqu'un en a un ? Des retours ? Un avis ? Je me dis que je suis plus prêt à passer par eux que par eBay ...
Par exemple, remise en couleur noir de l'intérieur de la chambre ou un mécanisme qui permettrait de relever le miroir avant de déclencher (ce qui permet de diminuer les vibrations en macro ou prise de vue de loin)...
Prix : environ 500$, cad 375€... avec un an de garantie...
Avis en fr : http://www.galerie-photo.org/n2-f1-104208.html
http://araxfoto.com/cameras/arax-cm-mlu-start/ (made in Ukraine)
ARAX-CM CAMERA DESIGN UPGRADE FOR PROFESSIONAL USE
The following operations are performed by professional technicians on all ARAX-CM cameras and their component parts. These operations are a part of the extensive re-work and upgrade process performed on all hand selected ARAX-CM cameras:
1. A rebuild and upgrade of the shutter mechanism improves reliability and guarantees a much longer life span.
2. This rebuild and adjustment of the shutter mechanism results in precise shutter operation and the most accurate exposures.
3. The Pentacon Six breech-lock lens mount has been redesigned and upgraded.
4. The installation of a Mirror Lock-up system which operates independently of the shutter release mechanism. This feature eliminates any vibration caused by the mirror movement when doing macro photography or when working with long focal length lenses.
5. The ARAX camera is treated with a light absorbent internal coating, preventing any external light or flare, resulting in excellent image contrast.
6. The upgrade to a special durable, non-reflective black external finish (the original chrome finish is removed by a precision sand blasting process, and then a special new black finish is applied) make the ARAX-CM camera both durable and attractive.
7. The reassembly and adjustment of the film advance mechanism and examination for accurate frame spacing gives the ARAX-CM its smooth film advance.
8. We examine each film magazine for any light leaks.
9. The calibration of the camera body and the magazine working distance is done as well as the relative positions for both the body and magazine to assure interchangeability.
10. We check all lenses for alignment, sharpness, aperture operation, and make sure they have a correct infinity focus.
11. Our technicians disassemble the prism viewfinder, and eliminate any manufacturing defects.
12. Examination of the light metering controls takes place as well as various other adjustments of the prism viewfinders.
13. A professional camera inspection for full functionality is performed including a compatibility test with various German CZJ lenses.
All of this hard work yields a new GEM of a camera, with a reliable and accurate shutter mechanism, and silky smooth operation. Add the most reliable lens mount, the most accurate metering, and the brightest viewfinder on the market to the new spectacular look of the camera and you know you are using the BEST KIEV available!
Re: ARAX-CM/MLU starter kit ? Kiev88CM révisé/remis à neuf e
j'ai eu un Arax 88CM et un Kiev88 CM https://forum.35mm-compact.com/viewtopic ... 55&t=38640
J'ai d'abord acheté le kiev 88CM au USA, le premier reçu HS après 2 films à peine, donc retour au vendeur, ça m'a couter les frais de port et la douane à l'achat du premier :cry:
Le deuxième reçu fonctionne assez bien à part un léger "banding" au 1/1000, c'est un problème de régularité de déplacement du rideau.
Ensuite j'ai acheté d'occasion un Arax 88CM MLU d'occasion encore sous garantie.
Là le problème de rideau était vraiment gênant, j'ai contacté Arax qui m'a envoyé paitre (j'ai gardé le mail), sous prétexte que si je veux pas de "banding" c'est un appareil à obturateur central qu'il me faut :evil:
J'ai gardé le Kiev 88 qui marche pour utiliser de temps en temps des optiques sympathiques, mais depuis j'ai acheté un Bronica SQ-Ai pour assurer, j'aurai du commencer par ça :roll:
Modifié en dernier par Oriu le vendredi 06 décembre 2013 10:42, modifié 1 fois.
matb
Message par matb »
Arax qui m'a envoyé paitre, sous prétexte que si je veux pas de "banding" c'est un appareil à obturateur central qu'il me faut
Mais non ?!
Pourquoi mais non :?:
Oui, pourquoi mais non ?! :mrgreen:
Sinon, pour ma part, j'ai acheté à un vendeur ukrainien un Kiev 88CM, neuf et non révisé, ni par Arax, ni par Hartblei, et j'en suis enchanté. J'avoue qu'il tourne un peu moins depuis que j'ai le Blad, mais c'est toujours avec autant de satisfaction !
matb
Message par matb »
OK, c'est une expression fort utilisée sur Bruxelles; Mais non (sous entendu, ils n(ont pas osés t'envoyer promener avec cet argument tout de même) ?!
Voili voilou, m'en voulez pas, hein, je suis belge après tout... :oops: :oops: :oops:
Une fois acheté un objectif chez Arax. Service et matériel bien en ordre. Mais un surplus de 25 euro pour payer avec Visa était moins apprécié. Mes deux Kiev 60 viennent de chez Hartblei et fonctionnent sans problèmes. Mais beaucoup dans l'armoire depuis que j'ai le Mamiya.
Réponse d'Arax envoyé en MP :wink:
matb a écrit :OK, c'est une expression fort utilisée sur Bruxelles; Mais non (sous entendu, ils n(ont pas osés t'envoyer promener avec cet argument tout de même) ?!
On ne t'en veut pas d'être belge (surtout pas moi ! :lol: )...mais sur le coup, je n'avais pas saisi non plus.
Il est vrai que sans l'intonation ça le fait un peu moins ! :sante:
