Photo faite par tilu
Chimie 5168 / film Orwo NC 19
Corinne
Message par Corinne »
Hello tout le monde, je cherche des infos concernant le développement d'un film que j'ai trouvé : un Orwo NC 19 en 120.
J'ai fait le shooting hier et là voilà, je me retrouve un peu c** parce que j'étais persuadée que le traitement était du C41.
Par acquit de conscience, j'ai fait une recherche, et voilà, je suis tombée sur du process "Orwo 5168" et un mode d'emploi ici :
The formulae are from quite old book using old polish chemical substance names and in some cases it wasn't easy to look up as most resources on the web use new names. I used mainly wikipedia as source for translation of the names. I think I double checked but please read carefully.
The process is for Orwocolor NC21 but the book I have states it is also ok for older NC19.
Process 5168
Color develop (C14) 6-8min 24C +-0.25
Stop (C37) 2-5min 20-24C
Wash 4min 21-24
Bleach (C55) 4min 22-24C
Wash 4min 21-24
Fix (C71) 5min 22-24
Wash 8min 21-24
Wetting (F905 1+200) 0.5min 20-24
Dry max. 40C
Process 5168/1
Color develop (C14) 8-10min 21C +-0.25
Wash 2-5min 20-24
Bleach (C55) 5min 20-24C
Wash 5min 12-21
Fix (C71) 5min 20-22
Wash 15min 12-21
Dry max. 40C
Times are given for constant agitation.
Steps from both variations of process can be combined.
I haven't found formulae for F905 and I do not know if it is just wetting agent or if process needs formaldehyde stab.
Color Developer C14
Water 20-30C 750ml
Sodium hexametaphosphate 5g
Hydroxylamine sulphate 0.8g
CD-1 1.7g
Sodium sulphite (anhydrous) 1.2g
Sodium pyrophosphate 14g
Trisodium phosphate (12 H20) 11g
Potassium bromide 0.9g
Potassium iodide 0.1% 5ml
pH 11-11.2
Stop C37
Sodium acetate 15g
Acetic acid ("concentrated") 25ml
Water to 1000ml
Bleach C55
Potassium ferricyanide 40g
Potassium bromide 15g
Monopotassium phosphate 25g
Water to 1000ml
pH 5.2 +-0.2
Fixer C71
Sodium thiosulfate (crystals) 200g
Water to 1000ml
pH 7 +-0.5
Source :
http://www.apug.org/forum/index.php?thr ... lae.40572/
Est-ce que ça parle à quelqu'un ? Est-ce que ça tenterait un chimiste de me développer ce film ? (parce que perso, je me le sens moyen-moins, le truc, comme je n'ai que de l'équipement pour faire du N&B ainsi qu'un peu de collodion, et pas de labo en ce moment.
Corinne
Re: Chimie 5168 / film Orwo NC 19
Personne ? :cry:
Et sinon, puisque je vais devoir mettre les mains dans le cambouis, qui peut me dire ce que signifie ça (formule du dev. C14)
CD-1 1.7g
Merci :)
Apparemment, ça marche dans le C-41 mais c'est moche.
Il y a aussi la Bulgarie, l'autre pays du 5168 :mrgreen:
https://www.cpachem.com/shop/miscellane ... o_reagents
Corinne
Merci pour l'info de la Bulgarie, ça, ça va être cool :)
Sinon, le C-41, non, même à "froid", je ne le sens pas :?
Quant au CD-1, j'ai trouvé la réponse, c'est du : N,N-diethyl p-phenylenediamine sulfate :shock:
Corinne
Hello ! je vous tiens au courant de mes aventures de l'ex Allemagne de l'Est :)
En poussant les recherches j'ai fini par trouver quelqu'un qui pratique le procédé 5168 (et aussi le 9165 pour les diapo Orwo Chrom UT-18 parce que j'avais ça aussi :roll: ) et je l'ai contacté par mail. Il est en Bulgarie (Bravo thecoin, tu avais bien visé :bienjoue: ). Très sympa, le mec m'a expliqué plein de choses et au final, il m'a proposé (de manière exceptionnelle) de lui envoyer mes films pour qu'il les développe.
J'ai reçu ce matin les deux films. Un support très épais et pas souple, difficile à mettre à plat pour scanner. Enfin, bon, c'est fait.
Le film n'est bien sûr pas nickel, et les couleurs ont un peu passé et des poussières sont entrées. En même temps, avec une péremption en 1991...
Je suis allée cet été faire le tour d'un lac au lever du jour. La première photo juste à l'aube, la seconde à mi-chemin autour du lac, une fois le jour levé.
C'est sympa l'ambiance et les couleurs de la première.
Envol
Message par Envol »
Pour info, le CD-1 est un développateur (comme le phénidone). On l'utilisait dans la fabrication du révélateur pour film interpositif de cinéma si ma mémoire est bonne. Il était commercialisé par F.r.p.c Conquet (Mesnil Amelot 77) qui commercialisait aussi ses dérivés plus récent CD-3 et CD-4.
Par contre, pour en acquérir ce n'est pas facile car le conditionnement est industriel et c'est cher le kg. Et je ne suis pas sur que la société existe encore.
